Thought I would just add my $0.02.
Overall I really like the Dell 3415W. Size wise it is nearly the same exact height as my HP ZR2740w (2560x1440), just 50% wider. So when using with work, its great being able to have IE & Office split on the Dell then SQL on the HP. I don't really notice the curve, so not nearly the distraction some had complained about with curved displays.
As far as functionality, the Dell scores a solid 8/10. With the numerous inputs & the dual upstream USB (3.0) ports, it's just bliss when switching from my gaming PC (DP->mDP) to work (DP->DP) and not having to swap keyboard/mouse. The usb acts as though it's a KVM switch. This gets a 10/10.
The downside, is from the DP Out / Daisychain / MST not working correctly (2/10). Ideally I should be able to plug in the HP to the Dell DP Out, then simply swap inputs ( mDP -> DP) then be able to work on work PC using BOTH displays. Unfortunately this does NOT work. The DP out only recognizes the HP as a Generic non-Plug & Play display then limits the output as 640x480. I've tried several solutions from Dell.community and non of them work. Seems to be a widespread issue with Dell's implementation of Daisychaining/MST. (Google: Dell daisychain mst "640x480")
There is a "potential" +Plus in that Dell advertises the U3415W as being upgradeable via Firmware update.
From: http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=bsd&cs=04&sku=210-ADTR
Again, overall a great display for work/productivity, though lacking on some promised key features (DP out, lack of firmware updates). I understand I am nitpicking.. however when spending this much on a display, I think it is fair to be Ultrapicky.
Enjoy hassle-free convenience as you update your monitor’s firmware with the new Firmware Update Utility software.
