- 6 Sep 2008
- Near Hull
Hi,
Do the delta case fans on the overclockers webiste have the right information on them?
The 60 mm has a CFM of 37.6 which looks like it could be about right, if not a little bit low. but the 120mm which spins 2800rpm slower is stated at 190cfm, seems really high, is it actually about right?
120MM
- Speed - 4000RPM
- Output - 190 CFM
- Decibels - 59dBA
- Dimensions - 120x120x38
60MM
- Speed - 6800RPM
- Output - 37.6CFM
- Decibels - 46.5dBA
- Dimensions - 60x60x25
120MM
- Speed - 4000RPM
- Output - 190 CFM
- Decibels - 59dBA
60MM
- Speed - 6800RPM
- Output - 37.6CFM
a mere 370 CFM
