Now AMD, revive 4x4 and we can talk, 2x 4ghz phenom FX's would be sufficient for me.
What are the chances of an AMD platform similar to that of Skulltrail for Deneb?
Which boards have an SB750 southbridge?
the ones that are super-ripoff expensive and gay looking to boot :/
http://www.overclockers.co.uk/showp...A-s (Socket AM2) PCI-Express DDR2 Motherboard
if deneb takes off i'm sure there will be more offerings though
There are more mobos on the way which are far cheaper. The foxxcon is the most expensive.
ASRock AOD790GX
Asus M3a79-T Deluxe
DFI LANparty DK 790FXB-M2RSH
DFI LANparty DK 790GX-M2RS
DFI LANparty JR 790GX-M2RS
Gigabyte GA-MA790GP-DS4H
MSI DKA790GX Platinum
MSI K9N2 SLI Platinum
MSI K9N2 Zilent
BIOSTAR TA790GX
I'll be waiting for reviews of this and i7.
Which ever is the best might be what I upgrade to.
That is only if they are quite a bit faster than my current setup
Although I really hope AMD pull out a good CPU, we need some good compitition again
