Dentists...
We couldn't get a NHS dentist when we moved back to Swindon a few years ago. Went Denplan at a private practice - pretty good and even when there have been NHS dentists in the area taking on since, haven't felt compelled to change.
Denplan covers most of the basics and while it probably works out more expensive than NHS or private PAYG if all you need is a check up/scale and polish at least you're covered when something more complex arises. Emergency service good too, last time I needed out of course treatment was seen the next day.
My usual dentist (20+ years) has retired and his surgery got bought out and closed down within 6 months, stating I could stay on their books but would have to drive to Nottingham to their main surgery :eek: Now gone private with a highly recommended local dentist as he wasn't taking NHS patients on.
I go private, but he's a friend that gives me a "student" discount, and is VERY good. I'm sure NHS is great too, but I'd struggle to go back to it now.
Appointment done. In for 3:25. In the chair for 3:30. Check up completed in five minutes. Chatted about the rugby and boxing for 15 minutes while he waited for his next patient.
Every dentist I've spoke to said don't bother with DenPlan or anything like that. The amount you pay annually for two check-ups and a clean are usually cheaper than the annual payments and most plans cover pretty much nothing for repair work.
Well, for £16 a month, I don't care.
I get better quality treatment than from the other NHS dentists in town, that's not an opinion, it's a fact, so I am happy to pay it.
I also don't get any other charges for any other work carried out, so If I need something doing, it's just done, and I walk away without paying anything else.
I am a dentist, private, I treat patient referrals and restore failing adult dentitions.
It is a lottery, word of mouth is best like someone said. There are some very good, conscientious NHS and private dentists out there and recommendations are the way to go. Private fees vary.
You could call the owner of a local dental technician or two and ask who the better dentists are in your area, they will recommend a good one.
It is good if you have continuity and you get what you pay for.
Most people need a check up once a year, and a professional clean between once and four times a year.
You must get your chops, and soft tissues checked at least once a year, it includes an oral cancer screen.
Use dental tape daily and brush twice a day with a fluoride tooth paste. Reduce sugary snacks and drinks and you will maintain your teeth and dental work and need only minimum maintenance.
Best of luck
pod
Thanks for the advice.
By dental tape do you mean floss or is this some other product?
Most of my teeth issues now are due to poor habits as a teenager.
*Think* my dentist is NHS but you still pay regardless don't you? Think it's £18 for a check-up?
Yep, seems to be around that amount at my one, and £18 something for an emergency appointment, which seems to be all you can get at my dentist these days as they're super busy :mad:
My back right wisdom tooth will have to come out at some point soon after months of on/off pain :(
I've got an appointment for Oct 21st for a de-root and refill but the Dentist reckons I really need a crown at a cost of £222 but the only problem is every 3 days I have intense pain for several hours and I really can't wait but I also don't want to pay £222.
If it was my front teeth I'd find the money but at my age and where it is it might as well come out.
I pay myself and go to the local Polish medical centre. Much cheaper and the same quality.
Where's that mate? I use Inspire Dental on the Oxford Road, but if there is a good / cheap Polish outfit I'd use them.
Thanks for the advice. By dental tape do you mean floss or is this some other product? Most of my teeth issues now are due to poor habits as a teenager.
Pleasure. For most adults:
Tooth brushing twice, perhaps 3 ties per day - medium hardness, a named tooth brush like Colgate from the supermarket, you know a quality one, they last a few months until the bristles look knackered.
Fluoride tooth paste - see below
Dental tape
Possibly teepee brushes
Dental tape is like miniature cassette tape - easier to use, ask the dentist/therapist to show you how. You use it to 'wipe' each surface, not saw through the gaps.
If you have gum gaps TeePee's are great, again your dental team will recommend them if you need them.
http://www.tepe.com/uk/products/interdental-brushes/
If you are susceptible to tooth decay as an adult you can use this 'industrial tooth paste', it is not for kids:
http://www.colgateprofessional.co.uk/products/colgate-duraphat-5000ppm-fluoride-toothpaste/overview
I think you may need to buy it from the dentist, may be dentist only - not sure. I really recommend this high fluoride toothpaste if like me your are frightened of the dentist and don't want any dental decay!
Dental patients usually fall into two camps, either 1. susceptible to gum disease, or 2 susceptible to dental caries.
Removing dental plaque off your teeth x2 to x3 times per day helps both issues.
If your teeth are 'heavily restored' due to past dental decay, over time teeth with large fillings can require crowns, sometimes dental nerve problems arise and you can consider root fillings, perhaps on referral to a specialist, endodontist.
Some patients are susceptible to gum disease. They tend to need to see the dental therapist on a regular basis or a specialist, periodontist. It is a painless condition and another reason to see the dentist at least once a year.
If you are keen on keeping your teeth tip top - be sure to point that out to your dentist, they will be delighted if you are motivated.
Essentially if you can remove the natural daily build up of plaque bacteria off your teeth by cleaning them expertly two or three times a day, your teeth and dental repairs will last for years. :p
PS you don't need to use strong medicated mouth washes, the above remove the bacteria you need to remove. Don't need to remove the health ones.
