Deoderant on a plane - quick question
23 Oct 2002
Edinburgh/Southampton
Flying out today, I fly all the time but never usually use pressurised deoderant (i.e. Lynx). Is the metal strong enough to withstand possible decompression of the hold?
As long as it's packed in your case you should be fine. I dont think they usually pressurise the cargo hold unless they are carrying live animals or something
Enough is enough! I have had it with these mother ******* deoderants on this mother ******* plane!
I've been told to put it in my hand luggage and then on a different airline told to check it in - I don't think it matters but for my sanity I just put a roll on in my hand luggage now (long haul flights = stops = nice to be able to refresh yourself).
That would depend upon the pressure inside the aerosol, the altitude that you are flying at and the speed of the decompression.
Better to put it in the hand luggage.
I was told, that if it goes in the hold, no one cares... however if it goes in the cabin spray it first... (at home). I.e. if it's new, make sure it has had one spray.
Something like that.... sudden change in altidude can make it expand/contract...
Oh I dunno....
*gets coat*
You can take it in hand luggage as long as it is under 100mls and fits in the clear plastic bags they hand out.
