- 14 Jul 2005
- Birmingham
Hi all,
I will be be boarding out my loft for storage in the spring/summer and am planning for how I will go about doing it. It seems quite complex as there is no straightforward way to lay joists because of the arrangement of the existing supporting walls in this 1930's house which is an unusual shape.
I have created a plan of the existing framework of walls and showing how I might lay additional joists around this. I can attach ledger boards to two of the walls, the party wall at the top of the diagram, and a gable end wall on the right hand side. However on the other external walls I cannot access them because they are in the eaves.
There are three brick supporting walls that come up from the ground all the way to the loft, but they don't cover the part of the loft to the bottom left very well, and also don't cover the area around the hatch very well.
I have shown in my diagram where I might put some joists. One set on the left, spanning from the party wall ledger board to the supporting wall to the left of the loft hatch, with a bit of a cantilever to gain some extra area. One set on the right, spanning from the gable end ledger board to the supporting wall to the right of the loft hatch. And the section above the loft hatch can be filled in with some intermediate joists between ledger board, supporting wall and other joists.
But Im a bit stuck on how to complete the framing around the hatch itself and to the bottom section of the hatch where I don't have any supporting walls available unless I have some quite big cantilevers which not sure is advisable.
