- 14 Jul 2005
- Birmingham
I found a thread on DIYnot about someone who wanted to cut joists at an angle going into eaves. Seems to be ok to do. https://www.diynot.com/diy/threads/cutting-ends-of-new-loft-floor-joists.433570/
Still the issue of getting 270mm of height though. If I can use 6x2's into the eaves then I'd still need another 6" of height on top of this to insulate properly. Could be achieved by cross battening with another set of 6x2's but if I do that its twice the amount of joists.
I wonder if I could lower the amount of mineral wool insulation by insulating the rafters as well. So say 150mm of rockwool, and 50mm of celotex in the rafters. Or I could use celotex insulation instead of rockwool which I think would lower the required thickness?
