If you are using the mount that looks like it attaches to the mobo with 4 bolts , then it looks like a candidate for shorting.
x = Nylon or cardboard washer
- = CPU mount
~ = Motherboard
¬ = Backplate
Try this ( layer order ) :
x
x
x
You want to isolate the mount from the mobo.
Also check around it when in place that it is not touching any capacitors or any other mobo circuitry.
Mark
- = CPU mount
~ = Motherboard
¬ = Backplate
x
x
x
Mark
