Dfi Expert wierd issue
17 Aug 2005
Gloucester, UK
ok, i have been using my Nvidia network port for some time now, decided to hook up my other comp with ics, so i made sure that the Marvell was enabled in the bios. but no matter what , no lights will come on when a cable is in, its like its not working at all. i tried the usb ports that are part of that socket and they are fine. any ideas?
It sounds like a dodgy marvell port but id try a different bios just to check. Also are you sure you have it turned on in the bios and you have been through every section of the bios to make sure theres nothing else disabled?
yea its controled in the genie part of the bios. on / off makes no difference , still not available, i will upgrade to latest bios later just to check, if not i guess its RMA just for 1 port....damnit!
Do you definitely need a 2nd port? I tried to use 2 before to bridge a connection so my laptop could get www but it never worked - windows networking is useless
i used to use both on my asus, had it set perfect, just does my head in, bought this board last month! . ah well, ill just buy a router i guess
