DFI, PWmic chip, how hot can these go before they become unstable
6 Jun 2005
Church Fenton
I have an X2 overclocked system.
This is making the PWmic chip get rather hot in load can hit 50C easy.
I have put a a heatsink on it made from an old pentium one heatsink to try and keep it cooled down.
But what is the maxium temp that these can get to?
Okies, well hopeful a friend is giving me a RAM sink for it, so that will have better design than a hacked up P1 heatsink.
:) well least I know I have a little more heat room to overclock.
Ah crap my PWM IC idles at 46C and loads at 66C :o This must be the reason to my pc freezing during long gaming sessions!
I was about to make an new thread about this as my PWMIC is sitting at 60oC atm iam testing an overclock i have done on an 3800+ x2 so running 2 instances of prime95. What is the PWMIC reffering too? i dont have a clue :s
im not totally sure, but i think it controls the volts going through the different rails on your mobo.
why bother making a heatsink for it when theres already lots on the pwmic area? :S I just put an 80mm fan blowing directy over it. Now it doesnt go above 45c, would hit 67c before which made my 170 unstable at 2.8ghz
well i was told it was those heatsinks (would make sense having heatsinks on it seen as it gots pretty toasty) in the red boxes in the pic above, so thats where i put a fan directly blowing and my pwmic temps are now 20c+ cooler. Fan isnt anywhere near the rectangular chip
The heatsinks to the right of the CPU socket are the mosfets. The PWM IC itself is the large rectancular chip by the 24pin ATX connector.
However, the temp probe that is labled as "PMW IC" is just above the mofsets.
