Diagnose this problem for me
31 May 2010
Bedfordshire
Hi everyone, i need a bit of help with my Aunts pc.
She turns it off everynight. But sometimes it wont turn on.
This has happened about 4 times in the last couple of months.
The first couple of times, when i pressed the power button, there was nothing, no lights, fans lighting up, nada.
I removed the side, just pushed all the power leads down, (they were in fine), then the pc started up. :confused:
The last couple of times, exactly same thing happened, first it was completley dead, then after a quick check, the power/Hard drive lights would just flash on then off.
I thought the mobo might have been badly earthed, so i loosened the mobo screws, and it started up.
Tonight it has failed to start again. :confused:
Oh, she is mentioned to me, her electricity went earlier (prepay metre) and she said, since then, thats when the pc wouldn't start, and the last time it happened to the pc, the electric went as well
any ideas?
i am thinking its either a bad earth somewhere or the psu.
The only thing, i dont have a spare psu to try, i have my own, but if i put it in hers, i wont be able to use my pc.
Her spec.
E5200 @ stock
some acer mobo.
stock generic psu
2 gb ram
Hi mate, the fan just starts for a split second when the power/HD light flashes.
Jumping the 24 pin? is that the same as using a paperclip to test those 2 wires to test a psu? no not yet.
yes i have a multimeter, i will give it a try in the morning.
edit.
just tried starting it up, and now its working again.
I am thinking, if i test it now with a multimeter, its going to read as fine.
I am going to have to try testing it again, when its not starting up, the problem is, i dont know when this will happen again.
What GPU has she got installed and driver version?
Are you certain its not from Sleep of hibernate?
Does her electricity get cut off much with her meter with the above question?
:Edit:
Make sure when you ask she understands the difference in shutting it down and leaving the PC to Sleep/Hibernate
I assume you tried this but its not stated so thought i would just ask :)
On board graphics
Tried wiggling the mouse first, no joy. also when i press power button, at first nothing at all happened.
i will ask her, but she did say a couple of times the problem occured, was immediately after the electric went.
also she shuts it down through windows, i had to show her how, lol
Any power outage can cause havoc though!
Cant you stress that?
Just a though have you tried a BIOS update or look on the manufactures website just in case there is a fix for the issue?
What motherboard is installed anyway?
i have tried, but she is very forgetfull.
its a generic board from the purple place, i had a look and its even hard to get normal drivers.
i am going to wait until it happens again, then test the psu with a multimeter.
thanks for advice though :)
