Hi all. I've had this 2600k for a while now, and I thought I should ask how good my OC is and/or about offset voltage and OC'ing.
For years I've been running 4.3 max turbo at 1.320 volts manually. I'm pretty sure it might have gone a little lower, but I didn't test really. I want to get my maximum OC at 1.35.
I've been looking through some ASUS Rog forum threads going through the options on my Maximus IV Gene, and found reference to offset voltage. So I decided to play around with it and see what the 'base' for the offset was.
When left to auto, at 3.8 boost (stock?) the BIOS gives it 1.352V in Prime95. At 4.3 auto, it was using 1.424 (stopped it quickly obviously). I then tried to offset down by -0.075 (to get to 1.35 - the voltage I was aiming for), but ended in BSOD before launching windows (too low idle voltage?).
So I reverted back to manual, set at 4.3, with 1.350. In Prime95 it was using 1.360. I then set 1.340 in BIOS so it used 1.350. Testing at 4.4 at 1.340(1.350 load) resulted in BSOD too.
So my cpu does 4.3 at 1.320 maybe lower, but won't do 4.4 at 1.340 (1.350)?
Does it sound like I just got unlucky with this chip, or am I doing something wrong?
