What has that got to do with the wrong fuel being in the garages tanks?
I think he's just saying it's potentially further evidence that it's not the OP's fault.
Does that match the pump number and amount of fuel you put in? I've had situations before where they've mixed up the pump number/not heard you correctly and you end up paying for someone else's fuel!
It's in reference to this post:
Doesn't apply to the OP as it was the wrong fuel in the UL tank. But my bike (2001) will easily fit a bigger nozzle into the tank than the UL one not sure about newer bikes.
You's assume the petrol and diesel nozzles from the tanker to the petrol stations reserve tanks are incompatible (or would that be too easy?), never heard of the wrong fuel at the pump . Go to the garage and dip the tank yourself
So basically, it was nothing to do with the fuel or the garage - your bike just broke down.
And now it broke down because there a screw missing, but that screw has been found and upon inspection looks like one of those very dubious screws, one that looks like it has been removed.
I can understand your frustrations.
