- 2 Aug 2006
- Liverpool
hi whats the difference between antec 900, 900-2 and 1200, just wondering
what are these like for coolingthe 1200 is bigger the 902 is similar spec but smaller, the 900 is missing a couple of things like dust filters and fan controllers
whats the best way of turning off the blue leds
ok thanks how big a gfx card can it fitthe 200mm fan has a switch at back to turn the LED off
would a 295 fitive got a 285 in a 900, bit tight but it fits
would a 295 fit
would a 295 fit
