Difference between the Asus DSL AC88U vs Asus RT AC88U
26 Jan 2010
difference between the Asus DSL AC88U vs Asus RT AC88U
difference between the Asus DSL AC88U vs Asus RT AC88U ??
whats the difference?, its got a different price but its still a Asus AC88U router, nothing on the Asus product page,
Its confusing as they are both Asus AC88U Routers, very popular but the 2 seem different models below, they also have different prices,
can anyone advise?
as i dont want to get the wrong one for my fibre internet,
Im currently using a ASUS PCE - AC68 Wireless PCI-E Network Card with the older Asus RT-AC87U router
Ive upgraded my internal WIFI adapter card to a ASUS PCE - AC88 Wireless PCI-E Network Card so any info appreciated.
thanks
2 different routers same name 2 different prices???:
ASUS DSL-AC88U AC3100 Wi-Fi Gigabit Modem…£209.99
ASUS RT-AC88U AC3100 Dual-Band Wi-Fi Gigabit…£268.96
The DSL one has a DSL modem built in, the other one doesn't.
oh i see
so I have a bt fibre service, it looks like i also have a separate bt open reach dls modem that is connected to my current router, so I suppose i need the ASUS RT-AC88U AC3100 right?
so If i got the ASUS DSL-AC88U AC3100 then this one has a built in modem right, so if i got this one then i wont need the bt open reach dsl modem, i would just use the solo dsl version, ? funnily enough the dsl modem version is cheaper when its suppose to be more expensive?
If the DSL version is cheaper, then if its anything like my DSL-ac68u, you can just turn the modem off and run it exactly like a RT-ac68u, so I wouldn't pay more for the RT version.
EDIT - You should google for yourself though as I have no experience with that particular model
It seems like an eye-watering amount of cash to pay out for a home broadband router.
Do you need any of the features or are you just going on higher numbers = better than?
ive upgraded my wifi adapter to the Asus PCIE AC88
so im on the hunt for a router to upgrade my old RT AC87U
the routers im looking at look exactly the same, one with a built in modem and one without, funnily the one without the modem is more expensive
I want to use it with my BT fibre service and getting a router with high speeds with give me fast wifi in my home, just trying to figure out which one of the 2 asus routers im gonna get, its very cheap on a used version especially during the jumble, oh i mean jungle sales.
The DSL one seems the one to go for, it does ADSL/ADSL2/VDSL, cable and G.fast connections.
You should also be able to remove the BT modem and just use the Asus.
The other thing to consider is can a single wifi access point give good wifi coverage everywhere required? If one is enough and the location isn't a problem, then a router with integrated wifi (and optionally modem) is a good choice.
However if one wifi access point is going to struggle or the location isn't ideal for wifi then consider separating out the functions. I started buying ever more expensive all in one units (£200+) before separating wifi off and have never looked back. Easier placement of access point(s), no need to upgrade everything in one go etc is just a better way and not that much more cost.
