Differences between some Lian Li cases?
29 Dec 2004
Hi guys,
I currently have a LL v2100Bplus, had it for 6 months or so and absolutely love it - huge case with plenty of room for absolutely anything. I just noticed on the Lian Li site the v2100Bplus II! :mad:
I tried to compare the two and cant see any differences other than a different cooling fan above the GFX cards and not much else?
Does anyone (Yewen?) know if there are any other differences or improvements that could warrant me getting one?
Lets say, i might, possibly, be getting a slightly itchy order finger - what case would you recommend to replace a v2100...i like a nice bit of room to work in, cool temps, and sleek looks - don't care about size or money...what would you go for? :confused:
1 Sep 2005
Scottish Highlands
You've already pinted out the main(only?) difference between the v2100B+ and the v2100B+ II. So I would say, no it does not warrent you getting it unless you are having temperature problems. You might want to have a look at a LianLi pc-201 though. Essentially a v2100, but with a sexy new exterior. :)
9 Nov 2003
Leeds
The v1000+ and v1000+II have the main difference of instead of a blower fan they have a side grill and a mounting for a normal fan.
I never used the blower other than for testing so its a negative point having a grill on the side of that lovely case.
The PSU mounting screws for the back plate aswell have slightly larger hex screw socket things that you screw into. That is the only other change I have noticed really worth mentioning.
