Differing cassette / chain rings etc.
29 Sep 2010
Hello all!
Recently picked up a Giant Trinity TT bike from a local charity bike shop, so it's a bit of a weird one in the drive train areas..
So it has
Sram red etap front and rear derailleur.
Campagnolo 11 spd cassette, with campag crankset (athena 11)
I haven't looked at the chain but assume this is a campag 11 speed based on these changes by the prev owner.
On my road bike I want to move across my crankset, which is an sram red e1 chain ring with force crank arms, it's a 12 speed chain ring but I've heard this should be no issue if using with an 11 speed chain/cassette? Happy to be corrected here :p
What I'm wanting to know is can I keep the campag 11 speed cassette, or will I need an sram cassette ideally? I know I'll likely need a different BB which is fine, I'm just wanting to make sure on compatibility of the drivetrain before I make any changes.
I'm fairly sure the 12sp Sram isn't compatible with the 11 speed stuff (although is fine with the newer 13sp stuff), so i'd be surprised if it'd work with a campag cassette.
In reality it would probably work, just likely sound "clunky"
It's not a burning change thats needed, as bike will be parked for winter.
But I think I may just end up buying an SRAM cassette when I get a new wheelset, then get a 12spd chain for this and that 'should' be okay I think.
I think the main thing is that the 12sp SRAM changed to the flat top chain which causes some problems, along with different thickness of the sprockets.
