differnce between DVI and HDMI?
think one of the only differences is that hdmi brings audio aswell as video, not sure about difference in quality though as ive only ever had VGA monitors
You can send audio over DVI.
HDMI has MUCH higher bandwidth, however. Useful for 30" monitors I suppose although I'm too poor to have any first-hand info on that.
neither.
HDMI has higher bandwidth (10.2gb vs 7.9 for dual link dvi) and can send audio as well. hdmi can send up to 2560x1600 @ 75hz. so 30% higher bandwidth - not really much much more lol.
dvi the standard does not carry audio. adapted dvi sockets can carry audio, with the help from a specifially designed dvi > hdmi convertor.
all of this can be found in the wiki btw lol
How do you carry sound over DVI?? Do you mean for speakers built-in to monitor?
I have a 4870 and use on-board sound sound, would be great if I could use the sound on graphics card.
Graphics cards can wire audio to pins on the dvi connector block that can then be used with a sutiable dvi to hdmi converter (ati) or cable (nvidia) to carry the audio to an HDMI destination.
AFAIK dvi source to dvi destination is not audio capable, its not something thats in the dvi standard for montiors or tv's to follow.
I see,
So i'm guessing using the 4870 sound through my Aego2.1's is not an option?
