That is entirely down to the individual, and is often dependent on the person's age and/or what they grew up with.
I work much better with a digital display of a number for stuff like speed.
It's been proven numerous times that people can read an analog gauge more quickly than a digital, as you only need to see the position of the needle rather than actually read several digits (once you are familiar with the scale). An analog gauge also gives you trend information which a digital gauge does not, or at least requires a significant level of interpretation to judge. It's also far easier to read an analog gauge with peripheral vision. Look at a flight deck - even now critical gauges will be analog, even if represented as graphics on a display.
Digital is great where you need to read a static, or very slowly changing value to a large degree of precision, but that doesn't include speed or RPM and even engine temperature and fuel level are better indicated by analog gauges as you can immediately tell if there is a problem just from needle position.
) where you demonstrated the multiple and subsequent ways your M3 would tell you we had no fuel.
 Another £5. THREE QUARTERS.
