I did have have one like that
I have exactly the same one as IanH and I've had it 18 months. It's been fine, though it uses a screw attachment for th valve rather than a quick release clamp. This means that you inevitably lose air when undoing it.
I also use a separate tyre pressure gauge and always overinflate the tyres then reduce pressure to the correct level.
Ive used it pretty regularly, adjusting tyre pressures in the colder months when they are lower because of the colder ambient and also reinflating tyres after track days.
The air compressors with the screw attachment say that they overcompensate when inflating due to losing some pressure when in the process of removing the hose.
Have the halfords one pictured above and as suggested, also over inflate to about 2 psi to account for the little bit of escaping air. Had it close to 4 years now I think, still going strong with no issues.
Was looking at these earlier. Not a fan of the screw head, anyone recommend one with leaver or push valve or an attachment i can screw onto these for the same result
