I'm looking to get some Dimmable LED candle bulbs, and am after a little advice if possible.
I've been looking at these specifically. I've read up on this and understand I'm likely to need a new dimmer switch if I don't have one specifically for LED bulbs, however they seem to claim these should work with most, though I understand from what I've been reading I shouldn't hold out much hope on that.
Anyway, I figured I may as well order the bulbs initially and at least see if they work with my dimmer, and if I don't then order a new switch, so here are my questions.
- If they are not compatible with my dimmer switch can I damage them (or anything) in any way, or will they simply not work? Basically, do I have anything to loose by just testing?
- Am I wasting my time trying to use my existing switch and would I be better off just getting one that definitely supports dimmable LED anyway, and if so any suggestions as to a good one?
- If people think the claims are wrong and I'll need a new switch anyway are there any other bulbs people would recommend that they've been happy with, as I was simply going for these because of the hope they'll work with my switch.
- Anyone know much about colour temperature, I want bulbs that are similar to traditional bulbs and not too white, is 2700k good in this respect?
Any advice gratefully received. One final thing to mention is that I've no idea what type of dimmer I currently have as I only bought the house a few weeks ago, but they were using traditional bulbs so I'm guessing its a regular one (thought it doesn't seem very old)
Oh, I've found this which I think answers my final question.
http://www.lumicrest.com/images/color-temp-chart.jpg
** Do Not Hotlink Images **
