Direct X 11
18 Dec 2009
guys,
Just upgraded my card , been along long time since i upgraded , I know i have to remove all traces of the old drivers , but what about DX11 , i currantly have DX9. do i have to download DX11 and install after the card has been fitted?? Sorry if this sounds a newbie question
Regards
Dog09
Nope you shouldnt have to do that try running the heaven benchmark with the dx 11 setting and you will see what its like. The card will auto set its self in games if they are dx 11 then thats obviously what it will choice.
I have , a radeon x1950 pro 512 on DX9 running windows 7 ultimate , and my new 5850 should be here today if it can get through the snow , all i need to know is wether dx11 gets installed when updating the driver to the 5 series , or if i manually have to download dx11 and install??
Regards
Dog09
Oh yeah , thanks , so its just plug and play and install new driver then!!cant wait to see the difference between this new card and my previous one
Thanks a lot
Dog09
Enjoy mate, I would recommend using the in-built ati uninstaller first, the installing the new 9.12 drivers fresh, but it's not 100% necessary, you will probably be fine just installing the 9.12's straight off.
OMFG!! this card ROCKS!! well chuffed with my purchase just broke it in hours stint on crysis , hour on MW2 hour on GTAIV !! might aswell throw my 1950 away!!! was gonna try and flog it on e-bay!! well chuffed right now :)
Dog09
I bet you didn't know what hit you when you fired up that shiny new video card! :D That's one hell of a generation jump and I'm sure you'll continue to love every minute of it. Enjoy. :)
