Directory is Corrupted or Unreadable
Caporegime
25 Jul 2003
FR+UK
I have a folder on one of my hdds which says the above when I try to rename/delete/read it. Anything I can use to retrieve the data thats in it, and if not just purge it?
(Would booting to safe mode allow that?)
heh, i was out in a school all morning, just got back :)
i'd wait for more replies, as i've never come across this before, someone may have a surefire way of fixing it.
google suggests using data recovery programs and/or "chkdsk /f"
as i said above though, wait for more replies...
As said, chkdsk /f should work.
It will prompt you to force a dismount, choose no. Then choose to run at next restart. Reboot your PC and it should repair it.
make sure your backups are in order
might be worth running hdtune on it and doing a full error scan
