Never going to happen.
Technical possibility means nothing.
Yup, it was doable before, it will be doable with DX12, but no one will actually bother doing it properly because there is really no incentive or reason to do so. Even in the best case you'll have different hardware with different strong points and optimisations, it's too much work. You can do asych sli/xfire but again it's just not worth it. sli/xfire bring a lot of benefits but to focus the work on a smaller subset of situations which have greater results makes the work worth the effort. Spreading this work to dozens of different situations just isn't worth while, async xfire/sli is barely a thing(I think xfire does it... a bit... but no one really bothers, not sure SLi does it at all).
The simple assumption that each and every card has the same basic components, capabilities and horsepower simplifies the work done for xfire/sli compatibility so far that it makes the benefit/work ratio worthwhile.
Most things are technically feasible, but this is one that won't see any meaningful work put into it outside of maybe some niche company, kickstarter type nonsense or just some amateurs looking for a new project... nothing will come of it in the end.
If true then would physx still be disabled cos it detected a amd card in the system? Otherwise whats the point of diff gpus on the same system if not to use the benefits of features of both at the same time? Sharing power for fps and memory is what sli or xfire was for wasnt it?
One fat american and you could take out canada along with the usa.+1
If you reduce all the matter a person is made of into pure energy, the resulting bang would be enough to take out the USA several times over. It is theoretically possible but it is not going to happen either is it.![]()
We were also told that DirectX 12 will support all of this across multiple GPU architectures, simultaneously. What this means is that Nvidia GeForce GPUs will be able to work in tandem with AMD Radeon GPUs to render the same game – the same frame, even.
This is especially interesting as it allows you to leverage the technology benefits of both of these hardware platforms if you wish to do so. If you like Nvidia's GeForce Experience software and 3D Vision, but you want to use AMD's TrueAudio and FreeSync, chances are you'll be able to do that when DirectX 12 comes around. What will likely happen is that one card will operate as the master card, while the other will be used for additional power.
According to Toms Hardware there is a new thing called Split Frame Rendering... only it's been around for more than 10 years and is related to the origin for the name 'SLI'. Indeed they wrote about it in 2005 though they failed to name the nVidia equivalent (which was actually called Split Frame Rendering back then, while ATI called it Scissor Frame Rendering)
*slow hand-clap*
Edit: So further down the article they suddenly remember that it's nothing new. Weird.
I'd be amazed if this actually worked as good as current multi-gpu configs.
I also can't see why you'd want to.
Now you can get 2 970 with 7gb of ram![]()
