DiRT 2 Problems :(
8 Jan 2009
Gidea Park, Essex
Hi Guys.
I've been playing dirt2 but after like 5-10 minutes the game just locks up and then I have to get to task manager to find out that the game has crashed, I can't keep playing like this, it's annoying.
Does anyone know what it may be?
Thanks
Sorry
OS: Windows 7 Ultimate x64
GPU Driver: ATI CCC 9.12
It isn't a heat issue though, I'm gaming at 61c max
First thing to try is to remove any overclocks you have on your CPU,memory & GPU...
Put them all back to stock speeds and then test to see if it still crashes..
Also forgot to mention I've done that.
I've run my cpu at 1.4v 3.0Ghz just to check for stability, mem 2.14v 1066 and gpu hasn't been overclocked.
I mostly believe it to be a game issue because my other games just run fine.
