If i was to disable pagefile in vista, would i see a performance increase?
If so how do you do it?
Using 64bit vista, 2x250gb HDD's and 4gb of ram.
NEVER turn it off althogether.
A better idea is to research hacking windows so that it stops putting bits of OS in the pagefile for no reason. There are some naughty versions that come pre-altered, but as fat as I know it can be done after the fact too.
Make it very small if you must. My XP on a 4GB box had only 100MB of swap. Everything ran brilliantly and the only error I ever got would be when the machine had been sitting idle for hours....."windows doesn't have enough virtual memory". Proof positive that it does actually spend it's spare time idly wasting system resources, otherwise it may have noticed half way through a game don't you think.
In XP maybe it helped sometimes but in Vista it doesn't sine Vista uses RAM effectively anyway.
By feel. Vista just feels slightly quicker with no pagefile. With it sometimes there is a minor delay in something as simple as page transitions in IE if I have say 20-30 pages open at once as opposed to nopage has a very consistent feel to how quickly pages open. Boot times are about the same once the super/pre-fetching has finished (this is on a QX6850) on my X6800 Vista feels much quicker still than the quad with nopage and the boot time is approx 10 secs quicker even with a slower HD!Define "slightly quicker"? Are you sure you aren't getting tangled up in a placebo effect?
4GB of RAM on an average desktop PC is going to keep all the frequently accessed pages of memory in physical memory. So they are never going to be paged out...
