disk failure Raptor
Permabanned
1 Dec 2005
New build system 1 week old i have a raptor 37gb on windows xp was all working fine then today i got a disk failure msg wouldn't find the drive so what i did was open the case swap sata cables etc same msg then i started debug mode etc same msg then i did some more changes make sure all was in etc then windows started it said some ddl was corrupted
plus on the gigabyte ds4 motherboard few times i couldn't see the gigabyte logo bios screen on bootup plus it has reset all my overclocking settings and went back to the normal conroe e6400 spec
last thing i did install was gigabyte sata drivers
Is there any program i can run to see if the drive is ok now
Any help will do cheers
hd tune is all you need. it will read smart info from the drive and run a full surface scan test. will tell you if its the drive thats borked your or os install.
