Disk Storage for VMware Workstation
24 Apr 2007
All,
I've been trying to build VM's on my machine, but whenever I get the 3rd VM running, it grinds to a halt, which I think is disk contention.
My Current Rig is:-
Q6600 Running at 2.7ghz
4GB RAM (PC6400)
1 x 250GB SATA Hard Drive (Think its an original SATA) it about 5 year old.
Do you think replacing this with a single Spinpoint 1TB F1, would make things a lot better, I know I should look at Raid 0, but its expensive.
Cheers
I would say 1 disk per physical machine would be better.
Having 3 virtual and 1 physical machine accessing 1 physical disc is going to cause issues, remember the read/write head can only be in one place at once ;)
my motherboard has two sata controllers. i run a 160gb drive on one of the controllers for the host os, and then i run another 160gb drive on the other controller to host the vm's. i recently upgraded my 'media' drive from 500gb to 1tb as well, so the 500gb drive has been cascaded down into the vmware box too. if i need extra performance then i spread some of the vm's onto that as well. works a treat once you seperate out your guest machines from your host.
