Disparate help needed ASAP , after trying oc I am locked out of bios
It's on the motherboard,a big silver round battery,pinch the clips together and it will lift up and pop out,if there's a clear cmos button at the back of the pc press it,but the best method is battery removal
It will be toward the bottom of the board,where the graphic card is
Ok thanks loads for the extra info their , I have now found the battery and done the CMOS reset and I'm able to access my bios and my desktop again so feeewww ... But now I'm left with windows telling me my copy of windiws 7 is not genuine ?? I know it is .. So why is this happening now .. Am I going to have to buy a new OS ? Or is their a fix for this issue also ?
Again please help
Press the CMOS clear button on the back of the machine. Hold down for about ten seconds then try boot.
Alternatively remove the Bios Battery and leave for ten mins with all power off then try boot. If it does not boot where does the system stop on the post display???
It only says this when you change motherboard within the system so this is very strange.
I can understand why the setting is gave you did not work fine either you need to explore this. The system should be at least booting up.
Try rebooting a few times,or re register your windows,the seriel will be on a sticker on the side of the pc if its a pre built machine,or on your windows dvd box
Ok .. Woooow that was all very worrying stuff .. But I have managed to re activate over the automated phone and everything is back up and running .. A really big thanks to all of you that have replyed very fast and helped me fix this massive issue
Thx
