Display Problem
19 Oct 2008
When booting up my PC my monitor makes a sort of buzzing noise then just goes quiet, it doesn't display anything at all, seeing this I was thinking my monitor is broken however when I borrowed another monitor from a friend it wouldnt work either. I'm starting to think it maybe a problem with the graphics card however I've taken the graphics card out and had a look at it, seems to be no damage to the PC and everything seems to be working fine but obviously isnt. Any suggestions or opinions on what you reckon the problem is would be much appreciated.
Specs:
Processor: Intel Core 2 Duo E6700, Socket 775, 2.67 GHz, 1066MHz FSB, 4MB Cache
Mobo: Abit IN9 32X-MAX WiFi NF680i SLI, S 775, PCI-E (x16), DDR2 800/1066/533, SATA II, SATA RAID, ATX
RAM: 2GB (2x1GB) CorsairTwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-12
HD: 150 Gb Western Digital WD1500ADFD Raptor Enterprise, SATA150, 10000 rpm, 16MB Cache, 4.6 ms, NCQ
DVD: LG GSA-H44NBAL 18x DVD±R, 10x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, IDE, Black, OEM
PSU: 650W Coolermaster eXtreme PSU (RP-650-PCAP)
GFX: XFX Nvidia 8800 GTS 320mb PCI-E
Thanks.
Usual procedure applies I guess, take everything out and boot it with minimal hardware in, and if it works, add stuff back one by one. If it doesn't work you've narrowed down the choices.
If you don't get anything at all it may well be the card. do you have another gfx card to test it with?
