Hey folks so as title says ive decided to build my 1st rig, always went pre build before but since reading these forums ive been inspired to build my own tower and trying to save money at the same time lol, ive seen through these forums people having good success and thought what the hell al give it a try, its great recieving a pre built rig but i want a project over the nxt couple of weeks to get me into building so im looking for some built and compatibility options from you guys
help me spend my £500 ish bonus from work lol the main rig is for gaming and playing dirt 2, codmw2, and other newer releases, i know i want the most upgradable rig for tweeking with in the future like just having a single gpu to start with but with enough spec to upgrade to 2 gpus in the future either sli or xfire, am open to either suggestion as ive used nvidia and ati before but they were in pre built rigs. also looking for a power supply to start with that will allow me to run 2 cards further down the line. im looking for a new motherboard that will allow me the most options when upgrading cpu power later on as well, like swapping over cpus that wont mean changing lots of other components if thats possible? thanks for any options you good guys in the know come up with, also looking to purchase the parts before xmas so im kept busy over ma xmas hols ..........
p.s. forgot to say i will be gaming at 1920x1080 plus got mouse/keyboard so just a spec for the rig pls
help me spend my £500 ish bonus from work lol the main rig is for gaming and playing dirt 2, codmw2, and other newer releases, i know i want the most upgradable rig for tweeking with in the future like just having a single gpu to start with but with enough spec to upgrade to 2 gpus in the future either sli or xfire, am open to either suggestion as ive used nvidia and ati before but they were in pre built rigs. also looking for a power supply to start with that will allow me to run 2 cards further down the line. im looking for a new motherboard that will allow me the most options when upgrading cpu power later on as well, like swapping over cpus that wont mean changing lots of other components if thats possible? thanks for any options you good guys in the know come up with, also looking to purchase the parts before xmas so im kept busy over ma xmas hols ..........p.s. forgot to say i will be gaming at 1920x1080 plus got mouse/keyboard so just a spec for the rig pls
which would be best for gaming at my res? i will prob run in xfire further down the line just need the best one to start with, going to order the parts tomoz so any other info would be appreciated, also i have a copy of windows 7 so sorted there
