Do cables matter?
18 Mar 2009
I have a 24" screen that i will probanly run at 1900 x 1200. I have a hdmi and a vga cable and both are suported. Will tje quality be effected by wiich one i use? Thanks
As beerbaron said most come with two DVI outputs, but you can get a DVI-HDMI converter very cheap (some cards actually come with them now) which would allow you to use HDMI from the DVI port.
Hawker
