Do current gen NICs work with any cable?
26 Feb 2004
Hampshire, England.
Hi guys,
Just an observation but do all new NICs work with all types of Cat wiring? Both standards (A & B) and straight/crossover?
Its just I was just doing some testing with an old hub and I inadvertently used a crossover cable between the hub a host - that didn't work (the machine is about 12 years old) however, before I realised I tried the cable in another machine (about 3 years old) and it worked...
I was under the impression that crossover could only be used, peer-to-peer :confused:
Most newer NICs will do auto MDI/MDIX so they'll automatically cross/uncross a cable if they detect it's required. Newer switches will also do this.
Most logical explanation is that your old machine's NIC doesn't support auto MDI/MDIX and your new machine's NIC does.
