- 4 Nov 2013
Using this review as an example:
https://www.rtings.com/monitor/reviews/lg/38gn950-b
In the response time section, it recommends the FAST setting at its max refresh rate, and NORMAL setting at 60hz.
The questions is, if I use FAST setting + max refresh rate (lets say 160hz), will I achieve the same rise & fall time / Total response time / overshoot error, when my FPS in gaming is 160fps and 60fps?
If that is the case, is that mean the FPS will not affect the rise & fall time / Total response time / overshoot error, it is only affected by where I plug the monitor to? Such as PC (160hz) vs console (60hz)?
Basically I am trying to use one overdrive setting for gaming, so I dont need to switich it to a different overdrive setting when I play another game.
Thanks guys!!
Thanks guys!!
