- 18 Mar 2011
- East London.
i have a 1.5GB PNY GTX 580 - not overclocked. Im looking to go from my Dell U3011 to a 3 monitor portrait set up, possibly with 23 or 24 inch monitors.
Will the 580 suffice and give playable FPS?
If not, then what are suitable upgrade options?
Im open to both AMD and Nvidia.
I would consider SLI/Crossfire.
Budget wise i would like to stick to middle of range, 'bang for your buck' options/cards.
CPU is an i7-2700k and mono is Gigabyte Z77 UP7. Everything is stripped down at the moment so its a non working pc for now.
Thanks
P.S wrong part of the forum i know but if anyone wants to recommend monitors then feel free, please remember they must allow portrait orientation.
Thanks
