Do i have enough power ??
23 Apr 2009
Derby
i was wondering how many watts these fans use at full load as i want to instal 10 of them in my pc
but heres the thing if i use ohms law...
P=VI (watts+volts/amps) that makes these 12v X 0.53 = 22.6W
my fan controller is only 30W per cannel and wanted to put 2 fans per channel
and also that 226w's for fans let alone my 180mm and 140 silverstone airpenatrators iam planing on
also with my rig in sig iam about to go Tri sli with 3 rads and will be running 5 HHD's also with 1x 180mm and 1x 140mm AP fans
some how i have a feeling my AX1200 might struggle with all this as with just 3x120mm fans, 1x140mm 2x 180mm and sli 470's my 5v's are getting low after playing BF2BC2 for a couple of hours
also my rig was enough like it is atm to shut my old toughpower 850W if i didnt keep my 470's below 750/1500/1648
advice and exerinace would be great as i dont want to buy it all and not to work properly :o
Please dont take this the wrong way but, i am not looking for people go yer that should be enough not owning high powered rig as i need words of experiance of you foldding and hardware enthusiast's
Many thanks and have a good night :)
