do i need a new cooler
23 Jan 2003
N.I.
i am thinking of upgradeing my system soon to a
p35(thing ill go for the asus p5k deluxe wifi)
c2d e6600
ocz 2gb pc2-8500(might buy 2 of these to have 4gb)
i will be keeping the 8800gtx i have in my current system
what i want to know is that i have a Scythe Ninja Plus Rev.B in my current setup. is this enought to cool the e6600 under a small OC or will i need a better cooler
Yes, the Scythe Ninja will do just fine cooling an E6600. Also, if your going for 4GB memory, then you'd be best off buying a 2x2GB set rather than using 4x1GB. It's meant to offer better performance and is significantly cheaper.
I had a ninja on my e6600 up to 3.2ghz and it was fine. It's a great cooler and certainly isn't far off the current crop of 'top end' C2D coolers.
You'll be totally fine IMO. :)
Also agree with the 2x2gb ram suggestion from Alex UK.
The 8500 is far too fast for the e6600 anyway. I made the mistake of getting some as it looked cool. Don't get me wrong though... it's great memory and i fully recommend OCZ.
However, if you were running 1:1 between memory and C2D your e6600 would be running at 4.8ghz which is rather fast! :eek:
Some PC6400 would be fine. That would give you 3.6ghz 1:1 which is closer to what you'd want while saving you a little cash! :cool:
THIS, THIS or THIS would be fine.
gt
