- 29 Feb 2012
I got separate cooler and all apart from CPU. Do I but oem or boxed version. Oem is 10 pounds cheaper...
thanks
thanks
I didnt know that. I have juts order the OEM 3570k.
However I think european law stipulates that all ectronics have a 2 year warranty anyway, the manufactures just dont tell you this.
UK law also states that buyers can get a partial/full refund up to 6 years after purchase. However the chances of this happening are small and even smaller if you overclock your CPU, as after 6 months it is up to you, the buyer, to prove that the fault with the product is an inherent fault rather than one caused through misuse (overclocking).
My guess is that Intel would state it as misusing the product as although we all know they are designed for overclocking, and will do so perfectly and be stable, Intel do not specify the product to run at such speeds and would probably state so as to not payout.
As mentioned above, OEM is the CPU only and with a 1 year warranty. The retail comes with the CPU, HSF, instructions and a 3 year warranty.
But if you don't use the boxed HSF with the retail model, the 3 year warranty is void.
Overclocking isn't really counted as "misuse" anymore.
How they gonna know if you OC and or use different cooler? There is no way of them finding that out ever.
You're running it out of spec, you are "misusing it".
