Spudgun said:Or will any SATA cable do?
Lord Alibaski said:The Yellow ones have a little clip on them but the red ones do not. I have never tried a SATA cable in a SATA2 slot but i doubt it would be good advise to do because they would probably be loose and fall out, because they are missing the clip thats on the SATA2 cable.
sr4470 said:As for SATA1 cables, the only difference will be burst speed limited to 150mb\s as opposed to 300mb\s with SATA2.
rpstewart said:The burst speed is determined by the drive and/or controller, not the cable.
sr4470 said:I was under the impression older cables didn't handle 300mb\s.
If you haven't noticed on SATA cables which are red SATA2 cables are Yellow.
