do i need to change something??
2 Jan 2012
Cambridge
I was running 8gb of ram ,Corsair vengeance 8gb ram (pc3-10700h)
and today i have put in 16gb of this stuff
http://www.overclockers.co.uk/showproduct.php?prodid=MY-094-KS
but if i go into task manager and have a look, it says it is
speed.. 1333MHz, but shouldnt it be 1600MHz
so do i need to change someting in the settings?
im on windows 8 64
thanks
ian
edited to say my mobo is a msi z77 mpower and a i53570k on stock clock
You will need to pop into the and check the memory options, there should be a option for XMP which should load the memory settings. If not you will need to manually configure the settings.
