Do i need to upgrade?
4 Feb 2004
Hello all, i am tempted towards either upgrading my desktop or getting a laptop. From my current desktop spec below, do you think i will be needing to upgrade to play games coming out in the next 12 months? And if i do upgrade, will a new mobo and an I7 with 16GB squeeze into my Antec?
Q6600 @ stock
8GB RAM
ATI R5850 1GB
Antec P182
Corsair HX620W
Thanks all
I would probably look at the i5 2500k, unless you require the extra of the i7.
This should fit fine in your current case.
Thanks both, will the current PSU cut it? Whats a good 16GB RAM Kit for the 2500k? Dual or tri channel?
I game at 1680x1050
Thanks
