I revisited diablo 2 not long ago, but had to stop playing due to the excessive amount of spam on each game you join/create, upon creating a game about 4 bots will join and fill the screen with SPAM for websites to buy game items and leave, and different ones will join after that and this will go on for a long time, the only workaround is to put level limits on each game you create but you will need to get some levels before you can do this (all spam bots use level 1 chars so set the limit so no level 1's can join)
Still as great if not better than it was at the time (thanks to the updates)
or play single player?
Game is so old, it's offensive to look at.
/player 8 ***!
OP, yes you should play diablo 2.![]()
I remember putting that command in for sp. What did it do just make the monsters harder as if you were playing with 8 people but also gettting loads more exp?
It's good with the screen res fix!, though gameplay is very good indeed![]()
The screen res "fix" will see you banned from Battle.net I believe (it certainly used to). Proceed at own risk.
Is it ok to use on the sp?
I'd have thought so. You won't be logged into B.net.
