Why not call and ask what machine they have?Well, would they typically have better equipment than a small side street place?
Simple question![]()
http://www.alignmycar.co.uk/
Use this website to find a local place that has a proper laser alignment machine.
[TW]Fox;15238399 said:Do this. Hunter = the best
I got mine done on the Hunter a few months ago and only the front needed alignment and it was around 40 quid, you can watch them do it aswell on the screens is some places so you can see how far out your car is.
[TW]Fox;15243101 said:A good allignment job if you need stuff doing might cost you £100ish but it's worth every penny.
The machine is only a small part of the job.
I've been to places with a Hunter and the guy told me he couldn't change the caster etc....![]()
I am intrigued, how did the other place change the caster angle then?
You should avoid just doing the front as it can knock the back out, it can be done if needs must, but it defeats the point in most cases.
I called the local bmw garage and they want 400 quie!
