Hey
I recently swapped out my thermaltake frio for the OcUK V8 watercooled kit. On the frio i could have both fans set to half and get high 60's when running prime 95 with AS5 TIM. I've got my fans mounted in a pull configuration as i couldnt physically mount them in a pull setup.
I've now got my W/C set up and after 15 mins of prime 95 my temps read 74c with my 2500k at 4.7ghz with 1.3811v.
The rad is only 30mm thick rather than the hspc 35mm one because it was out of stock and got the black ice gts 240 lite.
Ambient in my room is around 24c. I think i might have used too much TIM but what temps do you think i should be getting? Ill be removing the block tomorrow and re applying.
Cheers
Cheers
