Thanks must be the server i am selecting or the movie siteI've used PIA for years on Virgin with no problems.
No note used this service before (movies anywhere) but following what others have used in the last week, getting someone to try and set it up to see if its at my endHave you successfully used these VPNs with the services you're trying by other means? e.g. on your phone over 4G?
Reason I ask is because it is more likely the VPN is working fine but the movie service you are trying to use is wise the VPN and blocks it rather than your ISP. Netflix is notoriously good at detecting VPN usage and blocking you for example.
Which US movie site?Hi i am trying to set up a us movie account and tried tunnel bear and nord vpn both are know to work and both say connected but wondered if it could be anything to do with virgin ?
Thanks
Been using NordVPN for a good couple of years now on the SH3 - No issues![]()
Thought it was that, DNS alteration is better and more consistent than using a VPN.I'm guessing from OP's responses it is this one: https://moviesanywhere.com/explore
@COYS I use that for my work VPN and haven't had a single problem. It works absolutely fine .
