DOA graphics card?
4 May 2016
So I've just received my gtx 980ti in the post (also upgraded my psu to a 1050w). I've removed the drivers for the old gpu, installed the new GPU and the computer won't post (tried it without the GPU and it boots fine. And it works with my old GPU). Is the card DOA or am I missing something? I've tried switching between them multiple times so I'm sure all card must be seated and all cables connected properly. Any pointers?
It's quite common to have to update the BIOS to support more video cards, I have had this happen at least twice in the past 5 years. Should be ok.
Just had the thing booting (without connecting the GPU to power) after tinkering with bios settings. Powered down to attach it to the power and connect the monitor and keyboard and now back to no power. Guess that means the GPU isn't dead after all
Computer now powers on with the new GPU seated (without being connected to PSU) message on screen asking to power down & connect the PCI e cables (which I have done) and now it doesn't power again. Have I not cleared the cmos properly?
Try legacy graphics support (or something like that) in the Bios. It worked for me when I had a 280X on my Gigabyte board. Can you try card in another machine? If card is borked get your money back and wait for 1070/1080.
But there will be enough to power up motherboard and a ssd and the 980ti, you don't need all your hard drives to test just the os drive.
