Cant think of where to put this, so if is in wrong thread, can a mod please move?
Bought a 32 GB Micro SD card from 'The Bay' (probably 1st mistake there) and al;l looks good when i get the card.
Pop it into my card reader and copy all from my existing card (16 GB) over to it. All goes well there and all appears ok. Then go to copy over my music library as that was the reason I bought it and that's when things are starting to go odd.
The library looks like it has copied over correct, yet when i run music player, it sees no music. Browsing with a file manager shows that the MP3 music folder is empty. I have been through these steps about 3-4 times and the result is always the same, regardless of whether i transfer the files with the MSD card in a reader or in the phone (Galaxy SGS2 running DarkyROM2).
I did some Googleing and downloaded a program called SD Formatter (which was recommended by someone. This shows the card as formatable to 30.1 GB (as expected). Can run this and copy files over, yet when i put it in the phone, i am told the card is corrupt and needs formatting.
What the heck is going on here? Am i doing something fundamentally wrong or i have got a duff / bogus card from the seller? Haven't left any feedback yet either
