Does 720p have diffrent refresh rates??
4 Oct 2004
Hi guys,
Was wondering if any of you knowlegable people could answer a question for me.
I am currently having trouble connecting up my TVDrive to my Philips LCD TV and I have posted about this on another form.
One of the guys there says that I could be having a problem because there are diffrent refresh rates that the box and TV could be working on. He says that one could be 50Hz and the other 60 Hz and if thats the case it wont work.
I thought that if the TV said it supports 720p and the box supports 720p then they should work?
Had a good look about the Net and cant see anywhere that advises you to check that the TV and appliance work on the same refresh rate.
Is this guy just talking rubbish?
Thanks
John
coneypark said:
Hi guys,
Thanks
John
There is 720p/50hz and 720p/60hz.
Being in the UK it will be outputting 720p/50 - can your tv accept this ?
Also are you using a hdmi-dvi lead or convertor ?
Your TV carries the HD ready badge which means it should have no trouble at 50 or 60Hz so the problem is elsewhere, there are loads of issues with the TV Drives and HDMI at the moment.
The trouble I was having was that there was interference all over the picures,sometimes the pictured showed up and then disappeared to be replaced with static-as if there was no channel tuned in.
The engineer has actually sorted the problem though-it looks like it is a bad connection between the box and cable. If you push the cable fully into the socket then you get the above but if you pull it out slightly and get it at the correct angle then you get a prefect picture.
Telewest are sending me one of there HDMI cable and the company that sold me the cable are sending me a DVI-HDMI converter for the back of the LCD TV instead.
But everything is working perfectly at the moment
Thanks for your help guys-I wasnt sure if that person on the other forum was taking rubbish or not.
