mishima said:Hi there,
Just wondering Does a SATA HDD need molex power as well as SATA (flat power plug from PSU)?
Thanks
Street said:I somehow managed to plug both in on my Raptor a year or so back and ran it like that for about two weeks before I noticed, didn't seem to do any harm.![]()
Saxon said:Plugging both in can damage the drive. Use the Molex if you don't plan on hot-swapping drives.
mosfet said:AFAIK the WD Secure Connector just uses the extra power pins to make the cable more secure - no power is transfered. The other end of the cable simply plugs into the motherboard, which provides no power to SATA ports.
All the power is drawn from the 4 pin legacy connection.
Western Digital Site said:Important compatibility note: When using the WD SecureConnect cable, you must use the legacy power adapter because the SecureConnect cable utilizes the SATA power port to provide additional stability.
