Does anyone else get noise with upscaled dvd?
Most of my DVDs play really well through my PS3.
If you're having problems (and you're sure your TV is set up optimally) try the AV options while playing affected DVDs. There's filter settings for block/frame/mosquito noise reduction.
I've tried this with old TV shows, which gave very good results.
